Can`t build 1.1beta8
[root@bb:/usr/local/tmp/zabbix-1.1beta8]# ./configure --enable-server --with-mysql=/opt/mysql --with-net-snmp
[root@bb:/usr/local/tmp/zabbix-1.1beta8]# make
[....skipped...]
Making all in trapper
source='active.c' object='active.o' libtool=no DEPDIR=.deps depmode=gcc /bin/bash ../../../depcomp gcc -DHAVE_CONFIG_H -I. -I. -I../../../include -I../../../include -I/opt/mysql/include/mysql -g -O2 -c active.c
source='autoregister.c' object='autoregister.o' libtool=no DEPDIR=.deps depmode=gcc /bin/bash ../../../depcomp gcc -DHAVE_CONFIG_H -I. -I. -I../../../include -I../../../include -I/opt/mysql/include/mysql -g -O2 -c autoregister.c
source='trapper.c' object='trapper.o' libtool=no DEPDIR=.deps depmode=gcc /bin/bash ../../../depcomp gcc -DHAVE_CONFIG_H -I. -I. -I../../../include -I../../../include -I/opt/mysql/include/mysql -g -O2 -c trapper.c
rm -f libzbxtrapper.a
ar cru libzbxtrapper.a active.o autoregister.o trapper.o ../../libs/zbxdbhigh/libzbxdbhigh.a
ranlib libzbxtrapper.a
source='evalfunc.c' object='evalfunc.o' libtool=no DEPDIR=.deps depmode=gcc /bin/bash ../../depcomp gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../include -I/opt/mysql/include/mysql -I/usr/local/include -g -O2 -c evalfunc.c
source='expression.c' object='expression.o' libtool=no DEPDIR=.deps depmode=gcc /bin/bash ../../depcomp gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../include -I/opt/mysql/include/mysql -I/usr/local/include -g -O2 -c expression.c
source='actions.c' object='actions.o' libtool=no DEPDIR=.deps depmode=gcc /bin/bash ../../depcomp gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../include -I/opt/mysql/include/mysql -I/usr/local/include -g -O2 -c actions.c
actions.c: In function `run_commands':
actions.c:541: syntax error before `*'
actions.c:550: `cmd_list' undeclared (first use in this function)
actions.c:550: (Each undeclared identifier is reported only once
actions.c:550: for each function it appears in.)
actions.c:552: `alias' undeclared (first use in this function)
actions.c:552: `is_group' undeclared (first use in this function)
actions.c:552: `command' undeclared (first use in this function)
actions.c:558: `sql' undeclared (first use in this function)
actions.c:559: `result' undeclared (first use in this function)
actions.c:560: `i' undeclared (first use in this function)
*** Error code 1
Stop in /usr/local/tmp/zabbix-1.1beta8/src/zabbix_server.
*** Error code 1
*** Error code 1
Stop in /usr/local/tmp/zabbix-1.1beta8/src.
*** Error code 1
Stop in /usr/local/tmp/zabbix-1.1beta8.
FreeBSD 4.11-RELEASE
would provide any output needed..
[....skipped...]
*** Error code 1
*** Error code 1
*** Error code 1
*** Error code 1
